Intel IPEX的策略是优化现有优化器,而不是提供新的优化器类
31 Jan 2026 08:11 #1116 by service
=== Intel IPEX 优化器路径诊断 ===
操作系统: win32
Python 版本: 3.11.14 | packaged by Anaconda, Inc. | (main, Oct 21 2025, 18:30:03) [MSC v.1929 64 bit (AMD64)]
Torch 版本: 2.6.0+xpu
Intel IPEX 版本: 2.6.10+xpu
=== 检查 IPEX 模块结构 ===
1. ipex 主要模块:
   - FP32MathMode: <class 'enum.EnumType'>
   - WarningType: <class 'enum.EnumType'>
   - base_py_dll_path: <class 'str'>
   - builtins: <class 'module'>
   - cmake_prefix_path: <class 'str'>
   - compatible_mode: <class 'function'>
   - cpu: <class 'module'>
   - ctypes: <class 'module'>
   - disable_auto_channels_last: <class 'function'>
   - distributed: <class 'module'>
   - dll: <class 'str'>
   - dll_path: <class 'str'>
   - dll_paths: <class 'list'>
   - dlls: <class 'list'>
   - enable_auto_channels_last: <class 'function'>
   - frontend: <class 'module'>
   - fx: <class 'module'>
   - get_fp32_math_mode: <class 'function'>
   - glob: <class 'module'>
   - has_cpu: <class 'function'>
   - has_xpu: <class 'function'>
   - intel_extension_for_pytorch: <class 'module'>
   - ipex_version: <class 'str'>
   - is_loaded: <class 'bool'>
   - jit: <class 'module'>
   - kernel32: <class 'ctypes.WinDLL'>
   - last_error: <class 'int'>
   - llm: <class 'module'>
   - logger: <class 'intel_extension_for_pytorch.utils._logger._Logger'>
   - matches: <class 're.Match'>
   - nn: <class 'module'>
   - optim: <class 'module'>
   - optimize: <class 'function'>
   - optimize_transformers: <class 'function'>
   - os: <class 'module'>
   - path_patched: <class 'bool'>
   - pfiles_path: <class 'str'>
   - platform: <class 'module'>
   - prev_error_mode: <class 'int'>
   - proxy_compute_eng: <class 'type'>
   - proxy_log_level: <class 'type'>
   - proxy_math_mode: <class 'type'>
   - py_dll_path: <class 'str'>
   - quantization: <class 'module'>
   - re: <class 'module'>
   - res: <class 'int'>
   - set_fp32_math_mode: <class 'function'>
   - sys: <class 'module'>
   - th_dll_path: <class 'str'>
   - torch_version: <class 'str'>
   - transformers: <class 'module'>
   - utils: <class 'module'>
   - with_load_library_flags: <class 'bool'>
   - xpu: <class 'module'>
2. 检查优化器相关模块:
   ✓ ipex.optim 存在
      属性示例:
3. 检查具体的优化器类:
4. 检查 torch.xpu 优化器支持:
   ✓ torch.xpu.optim 存在
      包含:
5. 尝试创建优化器测试:
   ✓ XPU 可用,在 XPU 上测试
   ✓ 标准 torch.optim.AdamW: 创建成功
      优化器类型: <class 'torch.optim.adamw.AdamW'>
   ✗ IPEX 优化器 (尝试 ipex.optim): 不可用
   ✗ IPEX 优化器 (尝试 ipex.optimizers): 不可用
6. 检查 IPEX 优化函数:
   ✓ ipex.optimize 存在
   ✓ ipex.optimize 应用成功
=== 诊断完成 ===
关键点:Intel IPEX的策略是优化现有优化器,而不是提供新的优化器类。所以正确的做法是先用torch创建优化器,再用ipex优化它。🚀 优化器创建流程总结根据诊断结果,正确的XPU优化器创建流程是:
  1. 使用标准torch.optim.AdamW创建优化器
  2. 使用ipex.optimize()对模型和优化器进行优化
  3. 返回优化后的优化器
这就是为什么之前会失败:代码试图调用不存在的ipex.optim.AdamW,但实际上IPEX不提供单独的AdamW类,而是通过ipex.optimize()函数来优化现有的优化器。
31 Jan 2026 08:13 #1117 by service
完整修复的trainer_utils.py (llama factory)
def _create_xpu_optimizer(     model: "PreTrainedModel",     training_args: "TrainingArguments",     finetuning_args: "FinetuningArguments", ) -> Optional["torch.optim.Optimizer"]:     """创建 XPU 优化器 - 修复版本(基于诊断结果)"""     if not is_xpu_available():         return None          try:         # 检查并导入 IPEX         try:             import intel_extension_for_pytorch as ipex             ipex_available = True         except ImportError as e:             logger.warning_rank0(f"无法导入 Intel IPEX: {e}")             ipex_available = False                  # 获取可训练参数         decay_params, nodecay_params = [], []         decay_param_names = _get_decay_parameter_names(model)         for name, param in model.named_parameters():             if param.requires_grad:                 if name in decay_param_names:                     decay_params.append(param)                 else:                     nodecay_params.append(param)                  # 创建参数组         param_groups = [             dict(params=nodecay_params, weight_decay=0.0),             dict(params=decay_params, weight_decay=training_args.weight_decay),         ]                  # 确定数据类型         if training_args.fp16:             dtype = torch.float16         elif training_args.bf16:             dtype = torch.bfloat16         else:             dtype = torch.float32                  # Windows XPU 特殊处理         if torch.xpu.is_available() and hasattr(torch.xpu, 'device_count'):             logger.info_rank0(f"Windows XPU 环境:使用 XPU 设备,数据类型 {dtype}")                  # 创建优化器         if training_args.optim == "adamw_torch":             # 使用标准 torch AdamW             optimizer = torch.optim.AdamW(                 param_groups,                 lr=training_args.learning_rate,                 betas=(training_args.adam_beta1, training_args.adam_beta2),                 eps=training_args.adam_epsilon,                 weight_decay=training_args.weight_decay,             )                          # 如果 IPEX 可用,应用优化             if ipex_available:                 try:                     # 应用 IPEX 优化                     model, optimizer = ipex.optimize(                         model,                         optimizer=optimizer,                         dtype=dtype,                         level='O1',  # 基本优化级别                         auto_kernel_selection=True                     )                     logger.info_rank0("XPU 优化器:使用 torch.optim.AdamW + ipex.optimize 优化")                 except Exception as ipex_err:                     logger.warning_rank0(f"ipex.optimize 失败,使用标准优化器: {ipex_err}")                     # 回退到标准优化器             else:                 logger.info_rank0("XPU 优化器:使用标准 torch.optim.AdamW (IPEX 不可用)")                          return optimizer                      else:             # 其他优化器             optim_class, optim_kwargs = Trainer.get_optimizer_cls_and_kwargs(training_args)             optimizer = optim_class(param_groups, **optim_kwargs)                          # 如果 IPEX 可用,尝试优化             if ipex_available:                 try:                     model, optimizer = ipex.optimize(                         model,                         optimizer=optimizer,                         dtype=dtype                     )                     logger.info_rank0(f"XPU 优化器:使用 {training_args.optim} + ipex.optimize 优化")                 except:                     logger.info_rank0(f"XPU 优化器:使用标准 {training_args.optim} (IPEX 优化失败)")                          return optimizer                  except Exception as e:         logger.warning_rank0(f"创建 XPU 优化器失败: {e}")         # 回退到标准优化器         try:             return torch.optim.AdamW(                 model.parameters(),                 lr=training_args.learning_rate,                 betas=(training_args.adam_beta1, training_args.adam_beta2),                 eps=training_args.adam_epsilon,                 weight_decay=training_args.weight_decay,             )         except:             return None
