Driver confusions
2026-01-18 09:21 - 2026-01-18 09:28 #1035
Hardware:
英特尔® 酷睿™ Ultra 5 处理器 125H
Now installed检查已安装的驱动:
>> pytorch-triton-xpu 3.4.0
>> torch 2.8.0+xpu
>> torchaudio 2.8.0+xpu
>> torchsde 0.2.6
>> torchvision 0.23.0+xpu
批量卸载
# 批量卸载,一次性确认
pip uninstall torch torchvision torchaudio intel-extension-for-pytorch -y
# 或者分开卸载但都自动确认
pip uninstall torch -y
pip uninstall torchvision -y
pip uninstall torchaudio -y
pip uninstall intel-extension-for-pytorch -y强力清理(如果普通卸载失败)# 如果卸载失败,可以尝试强制删除
# 找到包的安装位置
pip show torch | findstr "Location"
# 手动删除残留文件(谨慎操作!)
# 通常位置在:Python安装目录\Lib\site-packages\
# 例如:
Remove-Item -Path "C:\Python310\Lib\site-packages\torch*" -Recurse -Force -ErrorAction SilentlyContinue
Remove-Item -Path "C:\Python310\Lib\site-packages\torchvision*" -Recurse -Force -ErrorAction SilentlyContinue
Remove-Item -Path "C:\Python310\Lib\site-packages\torchaudio*" -Recurse -Force -ErrorAction SilentlyContinue
Remove-Item -Path "C:\Python310\Lib\site-packages\intel_extension_for_pytorch*" -Recurse -Force -ErrorAction SilentlyContinue
Downloaded drivers:
Powershell
Install intel drivers
cd "E:\AI\driver\intel"
# 1. 先安装 PyTorch
pip install "torch-2.5.1+cxx11.abi-cp310-cp310-win_amd64.whl"
# 2. 再安装 torchvision 和 torchaudio
pip install "torchvision-0.20.1+cxx11.abi-cp310-cp310-win_amd64.whl"
pip install "torchaudio-2.5.1+cxx11.abi-cp310-cp310-win_amd64.whl"
# 3. 最后安装 Intel Extension for PyTorch
pip install "intel_extension_for_pytorch-2.8.10+xpu-cp310-cp310-win_amd64.whl"
验证安装是否成功
# 检查所有包是否安装成功
python -c "import torch; print(f'PyTorch版本: {torch.__version__}')"
python -c "import torchvision; print(f'torchvision版本: {torchvision.__version__}')"
python -c "import torchaudio; print(f'torchaudio版本: {torchaudio.__version__}')"
python -c "import intel_extension_for_pytorch as ipex; print(f'IPEX版本: {ipex.__version__}')"
# 检查是否支持XPU(Intel GPU)
python -c "import torch; print(f'XPU可用: {torch.xpu.is_available()}')"
如果安装Pytorch:
# 切换到目录
cd "E:\AI\driver\pytorch"
# 切换到目录
# 第一步:先安装 pytorch-triton-xpu(它是 torch 的依赖)
pip install "pytorch_triton_xpu-3.4.0-cp310-cp310-win_amd64.whl"
# 第二步:安装 PyTorch
pip install "torch-2.8.0+xpu-cp310-cp310-win_amd64.whl"
# 第三步:安装 torchvision
pip install "torchvision-0.23.0+xpu-cp310-cp310-win_amd64.whl"
# 第四步:安装 torchaudio
pip install "torchaudio-2.8.0+xpu-cp310-cp310-win_amd64.whl"
pip list | Select-String "torch" # 只查看torch相关
>> torch 2.8.0+xpu
>> torchsde 0.2.6
批量卸载
# 批量卸载,一次性确认
# 或者分开卸载但都自动确认
# 找到包的安装位置
# 手动删除残留文件(谨慎操作!)
# 例如:
Downloaded drivers:
Powershell
(Get-ChildItem -Recurse | Select-Object Name)
PS E:\AI\driver\intel> Get-ChildItem -Recurse | Select-Object Name
Name
PS E:\AI\driver\pytorch> Get-ChildItem -Recurse | Select-Object Name
Name
# 1. 先安装 PyTorch
验证安装是否成功
# 检查所有包是否安装成功
如果安装Pytorch:
# 切换到目录
# 切换到目录
# 第二步:安装 PyTorch
# 第四步:安装 torchaudio
Last edit: 2026-01-18 09:28 by service.
2026-01-18 09:32 #1036
Replied by service on topic Driver confusions
安装完intel的提示错误:PS F:\ai\fastapi> python app.py
Traceback (most recent call last):
File "F:\ai\fastapi\app.py", line 9, in <module>
import torch
File "
\Program Files\Python310\lib\site-packages\torch\__init__.py", line 262, in <module>
_load_dll_libraries()
File "
\Program Files\Python310\lib\site-packages\torch\__init__.py", line 258, in _load_dll_libraries
raise err
OSError: [WinError 126] 找不到指定的模块。 Error loading "
\Program Files\Python310\lib\site-packages\torch\lib\aoti_custom_ops.dll" or one of its dependencies.
安装完Pytorch的提示错误:
import torch
File "
\Program Files\Python310\lib\site-packages\torch\__init__.py", line 278, in <module>
File "
\Program Files\Python310\lib\site-packages\torch\__init__.py", line 261, in _load_dll_libraries
raise err
OSError: [WinError 127] 找不到指定的程序。 Error loading "
\Program Files\Python310\lib\site-packages\torch\lib\c10_xpu.dll" or one of its dependencies.
import torch
File "
\Program Files\Python310\lib\site-packages\torch\__init__.py", line 262, in <module>_load_dll_libraries()
File "
\Program Files\Python310\lib\site-packages\torch\__init__.py", line 258, in _load_dll_librariesraise err
安装完Pytorch的提示错误:
import torch
File "
\Program Files\Python310\lib\site-packages\torch\__init__.py", line 278, in <module>_load_dll_libraries()
File "
\Program Files\Python310\lib\site-packages\torch\__init__.py", line 261, in _load_dll_librariesraise err
2026-01-18 09:50 - 2026-01-18 11:01 #1037
遇到:Error loading "盘符
***\Python310\lib\site-packages\torch\lib\c10_xpu.dll" or one of its dependencies.返回只安装intel的驱动:完全清理已安装的
安装intel后,查看已安装:
PS E:\AI\driver\pytorch> pip list | Select-String "torch"
torch 2.5.1+cpu
torchaudio 2.5.1+cpu
torchsde 0.2.6
torchvision 0.20.1+cpu
***\Python310\lib\site-packages\torch\lib\c10_xpu.dll" or one of its dependencies.返回只安装intel的驱动:完全清理已安装的Code:
# 1. 先完全清理
pip uninstall torch torchvision torchaudio intel-extension-for-pytorch pytorch-triton-xpu -y
# 2. 删除残留文件
$pythonDir = "D:\Program Files\Python310"
$torchDirs = @(
"$pythonDir\Lib\site-packages\torch",
"$pythonDir\Lib\site-packages\torchvision",
"$pythonDir\Lib\site-packages\torchaudio",
"$pythonDir\Lib\site-packages\intel_extension_for_pytorch",
"$pythonDir\Lib\site-packages\pytorch_triton_xpu"
foreach ($dir in $torchDirs) {
if (Test-Path $dir) {
Remove-Item $dir -Recurse -Force -ErrorAction SilentlyContinue
Write-Host "删除: $dir" -ForegroundColor Yellow
# 3. 重新安装(先试 CPU 版本)
pip install torch==2.5.1 torchvision==0.20.1 torchaudio==2.5.1 --index-url https://download.pytorch.org/whl/cpu
# 4. 测试
python -c "import torch; print(f'PyTorch {torch.__version__} 安装成功'); print(f'可用设备: CPU')"
安装intel后,查看已安装:
torch 2.5.1+cpu
torchsde 0.2.6
Last edit: 2026-01-18 11:01 by service.
