Deprecated: Using null as the key parameter for array_key_exists() is deprecated, use an empty string instead in /var/www/html/plugins/system/t4/src/t4/MVC/Router/T4.php on line 388
mpdf 支持中文 - Bluetooth forum - bluetooth蓝牙技术
mpdf 支持中文
09 Dec 2024 15:38 #208 by btt
solved. I changed to mpdf,and Modify ConfigVariables.php under mpdf/src/Config:
'autoScriptToLang' => true,
'autoLangToFont' => true,
(Default is false)
So mpdf support Chinese characters.
