Display Total pages in dompdf
2024-10-09 20:39 - 2024-10-09 20:40 #202 by bluetooth
Link
Ha, I managed to display the total pages.
1. You must hack libraries\fabrik\fabrik\Helpers\Pdf.php - function iniDomPdf: around line 140 add $options->set("isPhpEnabled", true);
2. In your custom PDF list template's default.php (with some fixed header/footer) add e.g.
<div id="footdompdf"> <script type="text/php"> if ( isset($pdf) ) { $font = $fontMetrics->get_font("Arial, Helvetica, sans-serif", "normal"); $size = 12; $pageText = $PAGE_NUM . "of" . $PAGE_COUNT; $y = $pdf->get_height() - 24; $x = $pdf->get_width() - 15 - $fontMetrics->get_text_width($pageText, $font, $size); $pdf->text($x,$y, $pageText, $font, $size); } </script>
This will output "2 of 10" at the absolute position set by $x, $y.
It doesn't matter if you put it in the header or footer, as far as I understand it must be only inside a div that is displayed on every page.
Maybe we can add a textfield for additional PDF options in list layout settings.
Last edit: 2024-10-09 20:40 by bluetooth.
