查看: 434|回复: 0
How to enable BigDL-LLM on Intel® Arc GPU
发表于 2026-2-3 21:11:40 | 显示全部楼层 |阅读模式
Enabling BigDL-LLM on Intel® Arc™ graphics is a crucial make space unlocking their full potential. To do so, you’ll need the following:
Choose an Intel® Arc GPU: Ensure your server is equipped with an Intel® Arc GPU, such as the Intel® Arc ™ A770 GPU, or you can apply one from Intel Developer Cloud. These GPUs are designed to handle complex AI workloads and are ideal for accelerating LLMs.
Prepare your environment: Review the recommended requirements to install the Intel® oneAPI Base Toolkit and configure oneAPI environment variables as well as other environment variables.
Install the BigDL-LLM library: BigDL-LLM can be easily installed by executing this line of command:
  1. pip install - pre - upgrade bigdl-llm[xpu] -f https://developer.intel.com/ipex-whl-stable-xpu
Accelerating large models with BigDL-LLM is as straightforward as using it on an Intel® laptop — read more about it here or see an example of a LLaMa 2 model, as it is using the BigDL-LLM Transformer-style API which involves changing the model loading part, and the subsequent usage process is identical to native Transformers APIs. The way to load the model using the BigDL-LLM API is almost the same as the Transformers API. Users only need to change the import statement and set load_in_4bit=True in the from_pretrained parameter. You can also use the load_in_low_bit API to support other low-bit types.
# Load Hugging Face Transformers model with int4 optimizations
  1. from bigdl.llm.transformers import AutoModelForCausalL
  1. model = AutoModelForCausalLM.from_pretrained('/path/to/model/', load_in_4bit=True).to("xpu")
BigDL-LLM converts the model into 4-bit precision during model loading and optimizes its execution using various software and hardware acceleration techniques in the subsequent inference process.
  1. output = model.generate(input_ids.to("xpu"))
  1. output = output.cpu()
GMT+8, 2026-6-18 21:17 , Processed in 0.047589 second(s), 25 queries .
