查看: 390|回复: 0
https://github.com/intel/ipex-llm
发表于 2026-1-28 11:44:13 | 显示全部楼层 |阅读模式
[url=https://github.com/intel/ipex-llm/blob/main/docs/mddocs/Quickstart/install_windows_gpu.md]https://github.com/intel/ipex-llm[/url]
Install ipex-llm
With the llm environment active, use pip to install ipex-llm for GPU:
Choose either US or CN website for extra-index-url:
Note
If you encounter network issues while installing IPEX, refer to this guide for troubleshooting advice.
Verify Installation
You can verify if ipex-llm is successfully installed following below steps.
Step 1: Runtime Configurations
  • Open the Miniforge Prompt and activate the Python environment llm you previously created:
    conda activate llm
  • Set the following environment variables according to your device:
    • For Intel iGPU and Intel Arc™ A770:
      set SYCL_CACHE_PERSISTENT=1
Tip
For other Intel dGPU Series, please refer to this guide for more details regarding runtime configuration.
Step 2: Run Python Code
  • Launch the Python interactive shell by typing python in the Miniforge Prompt window and then press Enter.
  • Copy following code to Miniforge Prompt line by line and press Enter after copying each line.
    import torch from ipex_llm.transformers import AutoModel,AutoModelForCausalLM    tensor_1 = torch.randn(1, 1, 40, 128).to('xpu') tensor_2 = torch.randn(1, 1, 128, 40).to('xpu') print(torch.matmul(tensor_1, tensor_2).size())
    It will output following content at the end:
    torch.Size([1, 1, 40, 40])
    Tip:
    If you encounter any problem, please refer to here for help.
  • To exit the Python interactive shell, simply press Ctrl+Z then press Enter (or input exit() then press Enter).
GMT+8, 2026-6-18 21:20 , Processed in 0.043453 second(s), 25 queries .
